Intrusive97gsx
- 58
- 0
- Sep 10, 2002
Greensboro,
North_Carolina
Just wondering if anyone had problems with their Fuel Injector Clinic fuel rail? I was having a problem with my rail leaking from the upper o-rings with my PTE injectors. I replaced the o-rings a couple of times but it seemed to be an inconsistent problem. I then tried using some Denso 660's and it didn't leak. I noticed that the injector body was longer on the 660's so when the rail was bolted down it was sitting at a different angle. So I drilled new holes to mount the rail from (sits more vertical) and the PTE injectors are working fine now. I was just wondering if anyone else had this problem. The next problem I have to fix is the major boost leak that I have were the injectors go into the head.
