FIC 780cc???? Question!!
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
I could not find any information on the Fuel Inector Clinic site so hears the dealeo, I Have been runing FIC 650cc inectors, I am upgrading over the winter. My freind said he has a set of FIC's 780cc inectors. I got them from him to make sure they were lagit. Now my 650s, say FIC 125-650 on every injector. The "780cc injectors" say 29466/71083, 28566/61083, 26766/51083, 27666/61083 thease are the different numbers that are on each injector. He took them off of his 1g, they have black plastic bottoms on the head side rather than a metal horn shaped spout at the end like my 650s do. Here are some pics so you can see what im talking about!
http://i137.photobucket.com/albums/q218/lelej1080/injsemiclosegood-1.jpg
http://i137.photobucket.com/albums/q218/lelej1080/inclose.jpg
I just wan't to make sure they are what he says they are befor I buy them and get ripped off.!! Thanks for any help!! I need to get tis straight.:talon: :talon:
FIC doesn't make the X80 cc injectors, theirs are all X50, ie 650, 750, 850. PTE rates theirs as X80, ie 680, 780, 880, etc but they are they same injector as the FIC, PTE just rates their flow with a higher then industry std of 43 psi. PTE changes the end from the metal horn end that FIC uses to one that I believe looks like the one in the pic. FIC engraves the flow on the side of the injector, while PTE doesn't so I would say those are probably PTE. As for the flow not sure if you can tell what they are by the numbers they use.
I found this but it does not help much
Rochester Rochester "PTE" RC Flow
Part # Rating Size Average
17113738 50 lb/hr 550cc 515cc/min (estimated)
17113741 55 lb/hr 580cc 535cc/min
17113814 65 lb/hr 680cc 640cc/min
17113742 75 lb/hr 780cc 748cc/min
17113743 85 lb/hr 880cc 840cc/min (estimated)
17113744 95 lb/hr 1000cc
