FIC Injector question
Quasimondo
2,659
66
Jan 17, 2004
Washington,
I just installed a set of FIC 650 injectors, and they don't seem to be seating right. I can hear air leaking around the lower head seals (sounds like a pressure cooker when it's at full boil). Has anyone had this same problem when they installed FIC injectors? Am I missing something here?
This is the right seal, correct?
(click on pic for larger image)
Problem solved. I had to remove the spacers that went between the fuel rail and the manifold. I just replaced them with washers that I used as shims until it was seated nice and good. Good thing I bought a set of rings and seals before I installed everything.
are you sure that was a good idea not using those black spacers? Those things are there for safety purposes and so that you don't overtighten the bolts connecting the rail to the head. Ive read here about someone who didnt use them and his fuel rail snapped in half. Just thought id bring it up just in case.
I always use oem injector orings for FIC injectors, they are a bit of a pain in the ass to get them to seal good, but I'd much rather do that than remove the black spacers.
Get a new set of oem o-rings, and put the black spacers back in, very caregully guide the rail and injectors into their seats, and you will be fine, remember over tightening can tear the seals, so can tightening it down without the injectors properly seated
The noise you heard may very well have been a torn seal, when it comes to fuel dont mess around, pull the rail and check the seals, if you have a torn one you can blow fuel out under boost.. call me crazy, but that sounds like a bad idea
Matt
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
  • For sale OEM EVO 9 Injectors
    Selling a set of OEM pink top 560cc Evo 9 injectors. Had no issues with these and they have been...
    • tyvo98gsx
