fiav/isc question unblock
jbeaton9292
847
75
Aug 29, 2013
Sterling heights, Michigan
Ok so i have a 90 with a 90 turbo tb and i eliminated the fiav in turn eliminating the isc not what i wanted can i simply open the fiav back up and leave the coolant lines off and cap off the 2 ports so that the isc will work and fix my idle
Also could this contribute to a no start cold start i just replaced the cts and it was working good till i eliminated the fiav/isc? I would like to know before i buy yet another cts
Ok now im not trying to spend more money will my idea work as well? Anybody ever tried it; or if someone knows what cars the parts i would need to do that then i can snag them at a pick and pull
His brother Snowborder77??? (link Reference) sells a block off plate that lets you keep the ISC
EDIT: snowborder714
I cant use a blockoff plate my tb is a 90 and you cant inbolt the lower half like all the other tb's
Ummm thats no help i already have it blocked off i want to have control of my isc again as my idle sucks and i think its taking part in my cold start issue as the cts is new
Want i want to know is if i can simply turn the fiav back out but leave coolant lines off and just ports blocked so the isc works
try this
http://www.dsmtuners.com/forums/newbie-forum/323288-1990-fiav-blockoff.html
or post #19 http://www.dsmtuners.com/forums/bolt-tech/320799-my-solution-fiav.html#post151720501
