FIAV or ISC?
ByrdClaw
144
Aug 21, 2007
Sacramento, California
I have been having a bit of a slow surging problem on a cold start ups. I cleaned up my isc and put a new o-ring on. When cold it surges slowly and I have to keep my foot on the gas. When its warm I cant get the idle below 2K rpm's even adjusting the biss screw. Would cleaning out the FIAV also help the problem? Or does it sound like a bad FIAV or ISC?
if you could clean the fiav it could help... also make sure your idle adjustment screw is set correctly
yeah thats what i did when my idle was way off
It won't throw a check engine light either!
ohm out the ISC using the VFAQ guide if its fine then clean the fiav and adjust the idle with the idle switch unplugged
