FIAV delete issue/question
SPC2slowww
Sep 4, 2016
Calcium, New York
Ive searched and am tired of reading through dozens of threads and not getting my answer, so here is my question.
If i remove my coolant lines to the TB without either doing the free FIAV block off or using a bypass plate will that cause idle issues after warm up? Car stalls after driving for awhile, thanks.
Yes you will still need to do the block off, otherwise the fiav will never close, giving you high idle.
Are you currently getting surge or high idle? What is your main reason for wanting to delete the coolant lines to the TB? After I fixed my thermostat and replaced my iac, my idle issues have been solved. No more surge or wierd idle, and i was planning on turning the fiav in or deleting it.
if the car is dying after running for a bit, look at the iac or coolant temp sensors first.
