fastest with this setup
my97mitsGSX
248
Nov 13, 2003
Somewhere, New Jersey
what's the fastest 2g AWD on an ACT 2600 pressure plate with street disc? Just trying to figure out if i should sell my 2600 for a 2900 if i'm looking to run mid 11's.
I did a search and found a chart, but it only lists names and 1/4 mile times, not what drivetain, so don't flame or bi***!
ur stock with act 2600, and u want 2900? that seems a little extreme, if u have the money to buy shit to get u to 11's then 2600 would work fine just would need a race pressure plate.
if you are planning on running 11s, you should know what you need man, or else dont even head for that goal....
who says I was stock? i just did a motor build and wondering if the clutch i put on will handle the power I will be making..
yeah, i'm on 7 different forums, its hard to remember to update profiles :) Plus i had my 1/4 mile times posted, obviously 14.08 couldn't be done stock :)
my mods are this
Ross/Eagle Setup .20 over
Stock crank
New bearings
1g cams
1mm oversized nitrate coated SS valves
manley titanium retainers
crower valve springs
new front case/oil pump
new water pump
new water pipe
act 2600 w/ street disc - not sure if it will be good enough though
act flywheel
apexi gt exhaust
apexi gt downpipe
evo iii exhaust manifold
1g tbody
1g intake manifold
fp 3052
of course nothing is in the car yet, but i'm almost there :)
