FAQ Article Requests - post them here
Ludachris
Founder & Zookeeper
8,878
4,725
Nov 12, 2001
Newcastle, California
If you have an article you'd like to see written up in our Tech Article section:
http://www.dsmtuners.com/tech.php
Please reply to this post and request it. Make sure you've already looked through the articles section thoroughly to make sure you're not requesting an article that is already posted. No discussions here please - just requests.
i'm wondering if its possible to put in a turbo 91' FWD six bolt 4G63 turbo motor/tranny, into a non turbo 89' mitsu. GAlant FWD LS ( sohc 4G63)?
If its possible, please anwser or send info on the swap or where to go? :dsm:
ddavisaf said:
What do you mean exactly? Do you just want to know what to do with your coolant lines?
Nah, I'm just going to loop the water lines and stuff. I'd just like to see an official install complete with pictures, fitment comments, how the oil lines look hooked up to the filter, how things are routed, what people did with the lower intercooler pipes. Just lots of refrence pics I suppose. I've read almost every post on the T04B and several people have posted great pictures, but it'd be nice for a single encompassing article on it. :thumb:
i need to know where i can get the part that alows me to bypass my intake reading so i can up a vented blow off valve on my 98 gst... the part tell the ecu that its getting the same amount of air when it realy isn't if anyone knows where to get this part or has on for sale emial me at [email protected] thank you
Air Fuel Gauge Install in a 2G GSX, VFaq is not so good on this one, need more specifics then (may not match your modle since they did it on a 1G). I'm talking step by step with either wiring diagrams or pictures!
-CB
Could post a detailed "how to" with pics, on removing your stock suspension and replacing it with, lets say a TIEN or any other full suspension set up?
How about a how to on engine removal. Like, can the engine be removed with the trans or is it a two step function. I have searched the forums and the tech manual and cant find an answer to this question. What steps to remove engine only?
Thanks
i've been looking for maps for the emanage for a n/t turbo 420a , i've search 2gnt, looked at neon forums and still cant find any kind of emanage maps, the only thing i've found is the rotory setting are 38a or 3c1, i got the emanage and support tool, so if you have a map let me know
thankz
That part doesn't exist.
Thanks
You can do it either way. Simply drain all the fluids, disconnect all the wiring/axles/hoses, and remove them both OR you can drop the tranny first like you were doing a clutch job, and then pull the engine out afterwards.
If the fwd ls Galant uses an F5M22 then you may be able to use my tech article here. It's not exactly what you're looking for, but I doubt there are many people who have done that swap in the first place.
http://www.dsmtuners.com/forums/showthread.php?t=214201
jwahl425 said:
I, and many others on this site would like to see how to swap to a 1990 external air to oil cooler setup , complete with how to cap off the water pipe, where and how to mount the cooler, what cooler, etc. I think that this would be VERY helpful, Thanks!
I'm ordering my dsmmotorsport kit tomorrow and I'll do my best to show you guys what's involved.
I had a flat tire that caused me problems with my transmition after i put the wrong step tire (not knowing) and it was bigger than there other tires so it forced my AWD transmition as i drove home. It was so bad that the back started smoking in the rear transmition section. ( i think its called differential, but i'm not sure)
If there anyone that can help me know what going on???
Id like to see an article on how to install an MSD ignition on a 1g 1.8L engine. Ive never seen any articles anywhere and Ill be impressed if somebody can show how to do it. Thanks
Oil cooler install is finished. Article is in the tech archive.
I'd like to see a post with some pics of the ground wire for the starter relay. Prefferably on the harness by the fuse box. If someone could take a pic of the harness and the ground wire. I could wire up my starter kill, and coat it in Sonic Weld. There's just too many wires!!! Plus it's to easy to get into the steering column. Anyways, the help would really be appreciated!!! Thanks!!!
I would LOVE to see automatic to manual transmission swap i looked and couldnt find one but im doing my swap within the next 2 weeks and would really like a guide.:dsm:
