fan temp switch HELP HELP
sharky559
191
Mar 6, 2010
Sanger, California
the fans on my 95 eclipse gst are always on. dont know if its the CTS or the relays. also I cant find the fan temp swicth that makes the fans turn on when the car get hot. somebody ### help:confused:
There is no fan switch on a 2g. The CTS is what turns the fans on and off. If it was shot I don't think they would turn on at all. It sounds like a relay or someone wired it that way on purpose. Pull out your fuse box and look underneath it to see it it's been hot wired.
but you know what bro's when i jiggle the maf harness the fans stop. could it be the i got a bad harness. because i did check to see if my fans are hot wired but they are good.
