Coolant temp switch help!
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
Do i need my coolant temp switch if i dont have A/C. ALL A/C stuff has been removed.
Reason i ask is cus the little plastic plug on the coolant temp switch broke. Do i need to spend the money and buy a new one or will i be ok if i was to just take it out.
I haven't had the one for my ac in a while. Of course i don't have a/c and no overheat issues.
On this same topic which fan is the a/c fan?
All that does is tell the a/c fan to come on when the engine gets to a certain temperature. You can remove it if you want. Mine is off the car.
The a/c fan is the driver side fan.
  • Wanted 6 bolt NT water pipe
    • chrisman287
