Fattie92
- 607
- 3
- Dec 20, 2003
Waukegan,
Illinois
Well took it in today... and failed. Not to bad though, it should be a pretty easy fix, but just got a few questions... but first my results:
Standard Mine
HC- 220 436 Fail
CO- 1.2 0.6 Pass
Co2- NA 13.8 NA
NOx NA NA NA
The TEST:
Since i have an AWD car, they have to just rev it (im sure your all aware of this,) ... but there is a point in the test where the rpms, need to be held at 2500 for a certian amount of time. Well the guy that was testing it was a jackass and could NOT hold it at 2500. He kept going from 2000-3000. Not to sure if this fluctuating of the RPM would cause these readings or not.... but it was just a thought.
The FIX:
Well i havent touched the metering screw on my MAF, and wasnt to sure if backing it out would affect my HC's enough to drop 220ppm. I mean i can try it, and go back.. but id like to hear some info on that first. In theory i should be able to back it out (let in more unmetered air) and that should lean it out a little more. Sounds good right? THen there is just the basic tune up stuff to do, like PCV. Now i have never changed that thing, but ohh well. Spark plugs will be changed, and i can do oil again even though the oil in there only has like....500 miles on it.
so what do you all think? 220ppm over isnt all that much. Think backing out the screw will be enough?
PS.. mods are listed in profile
Standard Mine
HC- 220 436 Fail
CO- 1.2 0.6 Pass
Co2- NA 13.8 NA
NOx NA NA NA
The TEST:
The FIX:
) but I am having a similar prob. 4g64GST I was wondering what "air faults" means. Is that like boost / vac leaks?
