Factory Ignition circuit wiring
boosted5speed
Mar 5, 2003
Austin/lockhart, Texas
Does anybody have a picture/scans of the factory ignition wiring diagram for a 95 2g talon tsi. The car I bought apparently had an aftermarket alarm on it, I purchased it non-running.
At the present time, I can get it to start if i turn the key on and go under the hood and hotwire the starter solenoid, but cant get the key to do jack. Was looking around, noticed all the parts of alarm system, without the control box, fuses or anything else.
I need to find the wiring diagram so i can return everything to stock :) would be much appreciated. Any suggestions on where to get a factory service manual cheap?
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/RED
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/WHITE
Ignition #2:
BLUE/BLACK
IGNITION SWITCH HARNESS (HEAT-A/C)
Ignition #3:
N/A
Accessory:
BLUE
IGNITION SWITCH HARNESS (WIPER/RADIO)
Brake Light:
GREEN
(+) AT SWITCH ON BRAKE PEDAL BRACKET
Tach Signal:
WHITE
AT TACH FILTER OR POWER TRANSISITOR *
Parking Lights:
GREEN/WHITE
(+) AT RELAY OR @ FUSE BLOCK (FUSE 5)
Headlights:
RED
(-) AT HEADLIGHT SWITCH
OEM Alarm Disarm:
GREEN/WHITE
(-) IN DRIVER KICK PANEL
OEM Alarm Arm:
GREEN/YELLOW
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* 1.8L- Tach Filter Located On Front Center Of Engine. Has 3 Pin Plug, WHITE Is Filtered Signal To Tachometer, WHITE/BLACK Is From Coil. 1991-93 2.0L & 2.0L Turbo - Power Transistor On Passenger Rear Of Engine Below Coil.
Eagle
Talon
1990-1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE
Starter Kill:
BLACK/RED
Ignition +12 Volts:
BLACK/WHITE
Dome Lights/Superv:
RED/GREEN (-)
(-) PIN SWITCH OR AT COURTESY LIGHT
OEM Horn:
GREEN/BLACK (-) OR
GREEN/RED - STEERING COLUMN HARNESS
Power Lock:
BROWN/WHITE
AT RELAYS ON RELAY BLOCK
Power Unlock:
BROWN
TO LEFT OF STEERING COLUMN **
Trunk Release:
N/A
Alarm Input Wire:
RED/GREEN (-)
Notes:
** See Note #201 - Negative pulse Door Lock Diagram.
this is all i could find.........hope it helps some...........hotwheels of turborides
thank you :) hopefully I can figure something out with this. I have the alarm harness out now, and i have it to where its back to exactly where it was before (starts with the solenoid jumped, but no crank with the key) i just cant figure out what im missing :)
