EZ Bake Eclipse Build, Part III
rx7ttlm
342
May 20, 2008
Portland, Oregon
So I found more pictures of the engine build / install
Countersunk fasteners to clear the tensioner arm mod.
Evo III exhaust manifold prior to porting
EVOIII Manifold after porting and a slight blend, would have done more but I was in a hurry to get the engine done. The crappy part about this picture is you can't see the work that will make the biggest difference in flow :(
Short block with front cover mocked up and MLS head gasket layed up
Final assembly of bottom end
pistons that will probably crack under pressure LOL
Balanced / indexed pressure plate cover
Balanced ACT flywheel.. close but it was still off..
ACT flywheel with 20g in the background.. its kinda sad and needs a new buddy... That's why I got the DSM 76 from forced performance :)
Detail work on new couplers (I have no idea why they aren't solid black... )
Look like a hell of a build! I can't wait to see numbers on this.
What was modified with the tensioner arm?
I welded in a piece of cold roll steel across the back of the tensioner arm. Usually when you use the 2g motor mount (in a 2g) with the 1g tensioner you can't use the threaded timing tensioner tool when you want to change the t-belt or cams. I made it so that worked as factory so its not a pita.
e85_4g63;bt7941 said:
Damn you have a nice car man, motor looks awesome. Nice work!
That was the picture from when I got it back in like 2007, it looks like shit now LOL. The engine etc is like 6 months old with 5k on it. When I put the new turbo and intercooler in then its going to break gears LOL. Its more go than show now... :)
more show than go FTW!!
the pic in my sig is almost 2 years old and i refuse to post a recent one because i let the car go show wise. dings and scratches all over the place adding to my sleeper look..
Yeah, once I get my turbo and intercooler dropped in. It will totally be a sleeper. Black anodized intercooler, and kevin just layed down a 11.0 1/4 mile with the same turbo and a 2.3 on 93 with meth, I figure I will be around 11.5 with e 85. Not many daily drivers can run 12's let alone mid 11 seconds LOL.
The evil that comes next will likely be a hx35, or HTA gt35R with a 2.0 butchered crank(more likelt 35r with a FP hot side cause it would bolt into what I already have set up), maybe Aluminum rods with Ross pistons. :) Lets just say I like building engines more than anything else LOL.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
