2G Extreme rear camber
MITSUMURDOK
150
8
Jul 12, 2005
Newburgh, New York
When I went to put my new suspension in my 95 Tsi AWD I noticed that the rear drivers side wheel had some real extreme negative camber. This is with the stock suspension and the other side is sitting straight. I know something has to be bent or something, but visually everything looks fine to me. What could cause the wheel to rake in like this?
Knuckle, or upper arm issues. Check the bushings too.
If its just camber you can get longer bolts and add washers under the top A-arm mounts to push it out.
