2G Extra wire for Front O2 sensor?!?
USAF 98 GSX
132
Jul 17, 2012
Ladson, South Carolina
So a friend of mine has been having problems with blowing his 20A Engine fuse because of a short. Come to find out his stock BCS was stuck into his old SMIC hole in the fender and rubbed so much that it grounded out. However during our troubleshooting we were looking over all of the components within the Engine fuse circuit and noticed that the front O2 sensor had a bare steel braided wire that didn't belong. Does anyone know what this might be used for? Is it braided shielding? We are jus making sure all possible grounding points are fixed. Thanks
He did have a 99 GSX engine swapped into his 98 GSX because of crank walking, but the engine harness wasn't replaced. Not sure if that means anything.
Thanks in advance,
Sean
Is this the harness side of the wires or the o2 sensor side wires? Just clarify what colors they are aswell
Non-hacked harness and the bare wire goes all the way up to the main harness bundle
It's just inductive shielding. It actually goes all the way to the ECU.
Awesome figured but a bit paranoid since he's had a short for the past two days
Yeah, a few sensors have that going on. Knock sensor, both 02 sensors, generally anything that produces a voltage on its own. Good luck
BCS was the problem, car runs great, thank you everyone for the confidence boost.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
