extra pulley on water pump?
You cant remove that pully bc it will miss align your water pump belt and cause premature failure
my pulley was already not inline as it was on flipped see here. but now it's perfectly in line after i removed that extra pulley. would i have any problems if i run it w/o this pulley that was used for power steering which i also do no have?
Your waterpump pulley was probably backwards from the start. With the power steering and waterpump pulley's installed correctly the belt will ride normal. Even though it looks straight it may be a little off. Reinstall the pulley's correctly and have piece of mind knowing it's all on there right.
