external will not hold boost
carslinger
41
Jan 19, 2004
Round Rock, Texas
Ok here it is .... I have a 6bolt 1st gen w/9-1 pistons, web cams,1m oversize valves, turbonetics manifold, hks gt 3037 and tial35mm etc...... I have tried changing pressure signals, porting manifold, porting wastegate,wastegate port on manifold, changed wastegates...nothing works.
wastegate holds 9psi til apx 5k then from 5-6500 I get creep all the way to 21-22 psi.
Is it possable that:
A: wastegate is to small
b: not enough pulse from one runner to controll
These are the two possabilities that Im left with but...... arent there others running this type of setup on the steet?
help.....
help.....
What boost controller are you using? If its the AVCR electronic then you may want to mess with the boost curve and the duty that youre running. Also you may want to try a different spring in the wastegate. Hope this helps.
the 35mm Tial maybe too small for a turbo that size. Also, the spring in the wastegate might be too weak. If you got the 9psi spring, I'm betting it can't keep the valve closed at higher rpm, and is getting blown open. Swap in a 14 or 17psi spring. That should make it stop creeping. If it doesn't, then go buy a 40mm Tial.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
