External Wastegate broken??
LaBongJames95
Aug 7, 2011
milaka, Missouri
So i just got my car back from the shop because I had them install a new manifold external wastegate and turbo because I simply did not have the time to do it myself. I drove it around all weekend breaking the turbo in and everything was FINE N DANDY.. so i decided to take it up to school with me and i was just accelerating to pass a few cars and i realized i went from the set boost which was 10psi to 15psi which is way more then i want my engine to deal with, and i could no longer hear the wastegate. I pulled over and all the vacuum lines were attached and fine. The boost controller was still set in the same position. Any ideas?
the lines are set up connecting to the primary control port (which is on the back of the wastegate) to the MBC to the turbo.. is it more efficient to use both the primary and secondary(top of wastegate) control ports? i just dont understand how it was working great all weekend n then all the sudden just fails on me
As stated above, remove your
Boost controller. You want 10psi, you have a 11psi spring in your gate. Run what your gate spring pressure is. If your spring is 11.6 psi your lowest boost you can run is that spring pressure, so 10 psi is not attainable. Run a Line from your boost source to one of the lower ports on your gate, block off all remaining ports and leave the port on top of the Gate open. You should then be running your 11psi that your spring is.
Sent from my iPhone using Tapatalk
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
