Extended Crank Issue...???
nightracer91
414
6
Feb 27, 2006
Fort Wayne, Indiana
For the past two weeks, my 91 GST has had an extended crank. If I turn the key to "On," hold it for a sec to let the fuel pump run, it hestitates to start, then goes back to cranking. While cranking, usually giving it gas will get it to start. Has anyone else had this issue? Or has an idea of where to start...?
I have an extended crank issue with my 91 gst. If I hold the key at "On", then crank, it will hesitate to start but still cranks.... Usually, while cranking, if I hit the gas a couple times, it will finally fire up smelling like raw fuel. Anyone else have this problem, or know where to start?
