extended crank
Are you talking about where your starter keeps cranking after the car has started? Or are you talking about crankwalk?
When you do the six-piston mod, you have to add two more cylinders to the engine. In order to harness the power from them, you must use a crankshaft that has also been extended by two cylinders. Most use a Suzuki Verona crank for this mod, although it has to be clocked in order to attain the correct inter-cylinder pulse spacing. O, look everybody, another noob barge has hit the reef.
ROFL
