1G Ext Oil Cooler OFH which port is feed or return?
I believe the when bolted up looking at the front of the motor (timing belt side) oil travels from the pump, through the front case and through the left post first, then it loops through the cooler and travels back into the right post and through filter. Why do you care which way the oil flows as long as both your lines are connected to the cooler properly?
I am mounting it up so the lines are on the side,and I care beacause if you hook them up improperly(feed line on top),air bubbles will get trapped in the cooler.
Disconnect the power transistor so the car won't start and give it a couple cranks. The one the oil comes out is the outlet.
