2G T25 oil feed and oil return ports?
ameclipse
Jul 9, 2005
portsmouth, Virginia
OK this is my problem I'm putting a t25 on my 97 gs i know that there is a oil feed line and a oil return line. is the top line on the turbo the inlet for the oil feed and if it is where is it connected. is it connected to were you put the oil pressure sender sensor on the back of the block. i saw a line on the back of the block were the pressure sensor was on gsgoingfast thread and was wondering if that was it. thanks
The hole on the top is the oil feed. Usually bolts to the head right next to the thermostat housing. The Retuen line will come from the bottom of the turbo to the side of the oil pan by the bell housing.
Mike
Don't know much about the NT's, but I can tell you the inlet is the top and outlet is the bottom. Turbo guys can get their oil from the head or there is an open oulet on the oil filter housing. You may be able to do the same.
Yep...the N/t's have everything to bolt it right on in terms of the turbo oil line to the head and filter housing. They are just plugged with a solid bolt to the head instead of the banjo, and a allen head screw on the oil filter housing.
Mike
