Experts: 2G FWD Suspension Recommendation
UCspyderGS-T
51
Sep 16, 2005
Chattanooga, Tennessee
I have a Fwd 2nd gen spyder and it is time for suspension. I have read FAQs and other threads and don't like any information i see. The last time it went to the dyno it had 379 whp. I have a John Sheperd rebuilt tranny with Kaaz LSD. In the process of suspension i am installing FP cam2s, magnus motorsports sheet metal intake manifold, ported head with 1mm+ valves, and a FP Red. I need something that will help me at the drag strip besides slicks ( that one is a give). I have looked at and heard about:
kyb agx's: some people say they go out in like 16 months, and i know someone that put them on their car and it supposively made it looked jacked up in the rear. I have no idea what springs to go with on here.
Tokico Illuminas: These have been suggested to me and i thought about ordering the kit from nopi that has the springs to with a 1.5" drop. No postive or negatives about this have been heard of yet.
If i could get ideas on what other people have done to their fwds and positive and negative feedback about their setup and what has been heard of would help out tremendously and be great. Any recommendations will be taken into consideration.
Reminder: tranny and lsd so please make recommendations according to that.
Thank you
Michael
I've heard and personally seen Eibach Pro-Kit (1.3" drop) and tokico illuminas make a nice setup both handling wise, and power to the ground wise. But... being FWD, the best bet is to get wider and stickier tires.
I already mentioned i know about the tires.... I am going to go with slicks. I need help on the suspension aspect.
well it all depends on your budget as well.
i have a friend that had a fwd and used Tokico Illuminas with ebiach springs, and he was pushing over 400hp and did just fine at the track with drag radials
if you are wanting something that you can controll with out buying coil overs then you might want to look into koni adjustables, and tien springs.
What kind of numbers is he doing at the track?
i am cant remember off the top of my head but his username on here is twoboosted. he has his time slip on there. :) hope that helps
Thanks for the info. Can i get some more info from others looking to get a wide range of opinions and recommendations.
