exhaust removal & brake help
conor14
45
Mar 24, 2011
st. albert, AB, Canada
being as lucky as I am and living in Alberta cars get rusty ( jealous of some of the clean cars people in the states have )
the bolts are rusted and arent budging even with an impact. I'm at the cat right now and am just wondering how did you guys get it out? i tried cutting it but i cant get the sawsall in there enough to cut it out! ( yes im installing a 3inch tbe not just leaving it )
also, i just got brand new brakes ( pads and rotors ) installed and their squeaking. i took it back to the shop and they readjusted my ebrake cable ( they fixed it while i got my brakes done ) and there still squeaking, do they need to be worn in? or should i take my car back?
Get some type of penetration fluid. I used this stuff called Liquid Wrench and sprayed it a few hours before I did it and they broke loose.
That was my second attempt! First time I couldn't get them loose either.
As for The brakes I don't know much about them sorry.
If they're metallic pads they will make some noise when cold, but this noise would go away when warmed up (the heat "softens" the metal) Could be the dust shield (behind the rotor) rubbing against the rotor, that's usually what it is. if it is just bend it back, or remove them. if it's more of a tinny metal on metal scraping it's probably the dust shield.
PB blaster. Ill never use anything else. Spray it on the bolts, wait a while and try again. It literally turns the rust into water. There's a good article somewhere on here about breaking in your brakes
i got new pads and rotors, and the cold would make sense haha it only happens when I'm not fully braking and going like less then 15-20km like pulling up to a red light or pulling into my garage. Its odd and irritating! don't wanna spend a $900 on something thats not working properly!
i got half of my exhaust off just cause i got to get to school, it was a pain in the a** but i managed to get the saw in there and cut some of it off! Ill post a pic when i get my new exhaust on!!
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
