Brake Booster Removal Question
jmanjohnson1
Oct 13, 2012
Omah, Nebraska
I currently have a 2g 95' GSX and I am trying to remove the brake booster. I have removed the brake master cylinder and the hoes. Any suggestions as to how i pull it out? It is a stupid tight fit and most likely can't just pull out. I still have the entire engine in.
drain the reservoir first, disconnect the lines, use lots of rags + fender cover because brake fluid will eat paint. unbolt and slowly pull it off the rod. then unbolt the brakebooster and go for it.
does anyone know if a 1.8 brake booster is the same for the 2.0 it looks the same.
Thanks I did so but its huge and won't fit through the opening. I wondered if i needed to loosen a motor mount to move the engine forward. Any suggestions?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
