Parking brake cable removal
Artago
2,094
31
Nov 30, 2006
North Vancouver, BC, Canada
Trying to figure out the easiest way to remove the parking brake cables from the car.
I found this write up: https://www.dsmtuners.com/threads/parking-brake-cable-removal-installation-write-up.325346/
but the photos are missing.
Does anyone have a link where I can see the process in photos or video?
Thanks.
EDIT: I already have it disconnected from the brake hub and detached from the underside of the body. I'm looking for instructions to disconnect it and remove it from the interior.
You’re going to have to dig into your center console area. That’s where the cables meet with the e-brake lever. See the attached diagrams. It should be pretty simple, but you will have to pull up your carpet, etc to pull the cables.
I’m having trouble finding the 2G center console disassembly instructions, but if you’re a “go getter”, it shouldn’t be difficult to figure out.
