exhaust manifold nut
talon_frost
194
Feb 10, 2008
Kitchener,
Anyone know of a easyier way to remove the stock bolt on the 1g exhaust, the one right under the powersteerig, to the left of it, tried hard and its a bi*** becasue its tight as hell, I cant crack it loose with a wrench ???someone pleaze help me with this and tell me the ways of removing it LOL.
tranny fluid and I let it soak for at least 20 minutes , its rusted somehow???? and the gap to get any sort grip on it is retarded
what about removing the powersteering pump? will that give me a new angleto maybe get a wrench in there to crack it loose?
if you take out the two 14mm bolts that hold the powersteering pump on and slide it out of the way, you can then get a 1/4" drive and a 13mm in to get it off/put it on.
