exhaust housing clamp pressure
dboyle23
297
16
Jun 10, 2010
Chicago, Illinois
is there a specific ft lbs for the v band clamp that holds on the exhaust housing to the turbo? I thought I was getting an exhaust leak there because it wasn't on really tight. I was thinking this might be causing my late spool so I took it off but I am not sure how tight it should be. What ft lbs should it be at?
EDIT: So just tighten as tight as I can?
He is talking about the clamp that holds the hotside of the turbo to the cold side. Personally I dont think that overtightening that clamp will cause boost issues. Its designed to hold the 2 sides together and it does not have the power to cause any bending to the turbo material hotside or cold.
Id say just tighten it till it feels tight, around the same as your other exhaust bolts..
