Barracuda
- 51
- 1
- Jun 24, 2007
Finland,
Europe
Hi,
In the current setup (exhaust) I have a evo3 exhaust manifold, BEP 50 trim turbo, Megan Racing o2 housing and custom 3" exhaust starting from downpipe. I've set my boost to 15psi that creeps ~22psi by redline. There's a slight hint of a boost lag too... (15psi after 4000rpm, I've read that these turbos get full boost before 4000rpm?)
Now the exhaust isn't full 3" for the time when I welded it, I had a stock turbo and stock o2 housing. The stock o2 housing has approx 2.2" outlet so I bought a matching flange for it. Now the current o2 housing has a 2.5" outlet diameter while the DP flange is 2.2" making (perhaps?) nice restriction and turbulance. Not to mention the lost power.
The question however is, can that sudden restriction in gas flow cause slow spool and boost creep? Notice that the flanges mate right after the point where exhaust gas coming from the wastegate flapper meets the main gas flow.
