exaust for e316g
well any downpipe is good mines 3 inch dp and 2.5 out the exhaust, for my set up no test pipe just a pipe. for the evo someone else chime in, mines works fine.
I ran 3" all the way from the O2 housing to the muffler, then two 2.25" outlets from the muffler. Works for me.
nice muffler. I'm liking those tips. What kind is it?
A larger, free-flowing exhaust will allow you more potential power production, but it is more prone to boost creep on the e316g. I have a 3" turbo-back system with high-flow cat and I can't keep the boost below about 22 PSI at the top of 3rd on a full pull. In the lower RPM range below about 5k, I can can hold it to 15 PSI, but from 5k to 7.5k it begins to creep. Rather than spending money on an external wastegate setup to limit my boost, I installed a methanol injection kit to work with the boost creep. I can easily boost to 25 PSI @ 18 degrees timing without knocking on 91 octane.
As I understand, narrower exhaust systems will limit boost creep and ultimate power production, but I've never used a 2.5" system so I can't comment on how well it will keep creep down. As stated, if you're not after every last HP possible out of this turbo, go with a 2.5" system. Good luck.
Using a full 2.5 inch exhaust will absolutely help with boost creep, which is what the E316G is known for with those people using full 3 inch systems. Look at some past posts of Justin's (jusmx141). It will also help with noise suppression, if you're looking for a slightly quieter exhaust tone.
