Evoscan works on all Mitsubishi vehicles
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
I've been reading a lot about Evoscan this morning. From the looks of their website they are compatible with almost all Mitsubishis as of right now.
Supported Mitsubishi Vehicles:
1) Supports ALL USA/EUROPEAN/JAPANESE/ Mitsubishi Vehicles.
ALL Mitsubishi Vehicles with a 16pin OBDII connector, or 12pin connector, all Mitsubishis from 1994 onwards have one of these...
HighSpeed Datalogging - 200 dataitems per second!
Mitsubishi Evo 4/5/6/7/8/9, GTA/FQ, Lancer, Legnum, Eclipse, FTO, Galant, VR4, Colt, Mirage/Mivec Mirage, L200/L400* only works on particular Mitsubishi Diesel Vehicles, 3000GT, Pajero/Shogun, Diamante, Outlander, Montero, Magna, Expo, Verada, Delica, Spacegear/SpaceWagon/SpaceStar/SpaceRunner, Dodge Stratus, Eclipse GT/GS, Grandis, Carisma
Supported Subaru Vehicles:
1) Subaru Impreza, Justy, SVX, XT, Loyale, GL, GT, DL, Legacy, Baja, Forester, Outback, Baja, Forester, Impreza, Impreza, Legacy, B4, MY99, S/GT, RSK, STI, Turbo/WRX/GT, S/GT, S/GT Auto, RX, H6, STB, RS, GX, Type RA, Type UK, GLS, XT, Spec C, S401, Outback, H6 VDC, WRP10, Outback XT, Tribeca
OBD-I (12Pin) Supported Mitsubishi Vehicles:
EvoScan software is confirmed working with these vehicles, using the EvoScan 12pin OBDI Datalogger cable.
25) Mitsubishi Eclipse/DSM* (*1995/1996 full support not available yet)
26) 1990-93 Mitsubishi 3000GT/GTO
27) 1990-93 Mitsubishi Dodge Stealth
28) 1990-94 Eagle Talon, Mitsubishi Eclipse, or Plymouth Laser
29) 1991-92 Galant VR-4
30) 1993 Mitsubishi Lancer GTI 16v
31) 1989-92 Colt, Summit & Mirage (CSM)
32) 1992-95 Mitsubishi Evo I*, II* & III* (*full support not available yet)
33) 1990-1995 Any Mitsubishi vehicles fitted with a 12-PIN OBDI diagnostic port
Hybrid 95-99 DSM/3000GT/Eclipse (16Pin) Supported Vehicles:
EvoScan is the first to support these vehicles. Select "Hybrid" and select ECU "EFI" in EvoScan.
EvoScan software is confirmed working with these vehicles, using the EvoScan 1.3U Datalogger/Reprogramming cable.
34) Mitsubishi Eclipse/DSM (1995 and 1996 support Hybrid MUT Protocol)
35) Mitsubishi 3000GT (Hybrid MUT Protocol)
36) Mitsubishi Eclipse (Hybrid MUT Protocol)
So, I was curious if there were any comments about this. Most of the posts I read were pretty old. I've been looking for a logger that was able to work on all DSMs and all 3/Ss. This seems to be the way to go. Looks like there are some problems with 95/96 DSMs, but for the most part, it seems to be compatible with most Subaru and Mitsubishi vehicles.
Different cars have different data rates, but they all seem to be faster than using the OBD protocols. I get about 80 samples per second and am debating on switching to an Evo 8 ecu to tune the car. They have modified codes for those that result in data streams so fast it's nearly real time. (150+ samples per second). They can log fast enough that not all the sensors refresh the data fast enough.
