EvoScan - Does anyone use it??
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
I was looking at Evo tuning.. I was bored... and I stumbled across something that they use a lot as a logger. It is called EvoScan. I went on the web site: http://www.limitless.co.nz/#SupportedVehicles, and it actually says it works with our cars too and any mitsubishi up from 94 using the "MUT/MUT-II/MUT-III protocol" for the logging... This logger logs everything including knock sum.. would it be possible that because this logger uses the Mitsubishi protocol and not the generic obd protocol that it can log things that the other generic obd2 loggers can't?
hmm, no i dunno if that would work the way EvoScan will. It is a base program where EvoScan is loaded and wrote to do things specific with the Mitsu ECM. I'll buy the program if I cant "aquire" it ya know.. LOL.. But I do think I'm going to make one. I have a few old OBD/II Scanners with the changable plugs and one for the DSM is in here. I'll just wire my adapter to it as i think it should go then just put on a simple pigtale to my ground/bare and then plug it to pin1, or 9 (whichever needs to be grounded) and then I think I can just go from there. I think I'll buy that USB to UART Adapter tomorrow and wire it up when it gets here and try and get a copy of EvoScan :)
Yea but making one would be cheaper, $90 is a joke for something that cost roughly $25 to make... seriously...
I'll probably just take my chance doing it my way as I'm sure its basicly the same way they do it (not as clean) but will probably still work exactly the same.
Actually I'll do you one even better... Go get yourself a 4mm Pin Header from Radio Shack, a Serial Cable, and then all the parts on this here schematic.... and solder away. Then you'll have what you need (without the ODB2 adapter molding) But it will plug in... Then execute your EvoScan tool and have fun. Ta-Da... YAY ME!!
Kinda Crappy but here is a view of the Serial Plug...
and one of the pin-header...
Well if anyone does plan on ordering evoscan, make sure you understand it's going to be 2 weeks to get your cable to the US....still waiting for mine.
Are all those other parts available at Radio Shack too?
ok so remember my first post, where i said Evoscan told me this will work for my car? well it doesnt. i ordered it and plugged everything in and it fails to initialize. i emailed evoscan again and told them exactly what was happening. do you want to know what their response was? "thanks, ok I'll work harder to get the new version out to you asap. thanks again." that reply doesnt even make sense. they suckered me in to buy it and now im screwed. so i went ahead and bought pocketlogger and that works great.
I already posted a few times how Evo scan doesnt work.
They told me the exact same thing a year and a half ago. I dont know why people continue to buy this.
What doesnt it work with? There's screen shots of it working on OBDII's right in this thread. If it doesn't work for 95's that's not surprising. It was a risk you took as a 95 attempting to use it, sucks that they said it would work but perhaps the new zealand dsm's didnt have the same ecu to deal with.
95. The 98+ is only a new addition (When I first got it, even they were not supported)
And the ECU is the same every where int he world.
because i really wanted you to be wrong! LOL
Correct me if I'm wrong.. but don't the older ecu's need to change the baud rate?
i tried everything including changing the baudrate. it doesnt work for 95 cars.
According to the EvoScan website, there is now hybrid support for the 95/6 ECU to be released in v2.3. Anyone know if the Multiplex adapter will work for EvoScan?
Beta testing tonight if my adapter works, gonna be a week or two if i need to order one. -FYI i run a 95 EPROM in case anyone says duhh it works you have a 98....
hey guys, I went through the registration process to let you guys know that evoscan 2.3 works with 95-96 ecu's. He finally got it to work guys and its amazing!! tell your friends that have been waiting as well. Thanks
