First Evoscan log, mostly stock car, how does it look?
jason_gsx
35
Nov 22, 2011
Visalia, California
I just got my $7 OBD2 cable and Evoscan and ran a ~8 minute log. How are things looking? My wideband will be here in a few days so no data on that yet, I do have an Autometer boost gauge, K&N FIPK, FP AIP /w BOV Return Flange and a Hallman Pro RX MBC set at 14 PSI. It looks like there are a few knocks and it says my AFR drops below 10 a few times, but I don't know how much that really means using the OEM o2 sensors.
Looks overall decent. But your coolant temps are high.
A wideband installed and logged would be better. Same with a map sensor.
I've also got the P0120 DTC and the log shows my throttle position at 14% when I'm at idle. The car runs fine as far as I can tell though. Any chance they are related, or do I just need to adjust the throttle position once I get DSMLink?
Possible, start the logger and set the TPS to 13.33333333333%.
Thats the correct setting read in Evoscan.
13.333x is what the TB is set to, to idle correctly. About .6-.7 volts.
