how does my log look
Where there any WOT pulls in this log. It apears that you need to calibrate your tps sensor, it never showed 100%. i would lean it out up top a little bit, seem to run a little rich. Can you post an idle log at full operating temp? to check out your base idle tune
Should I add any other items to the graph?
Here is one i just did. Couple mins on the way home and idle in the drive for a couple.
