HyperGSX
- 1,167
- 1
- Oct 10, 2002
Schaumburg,
Illinois
I just purchased a set of evo8 560's. Is there anything else i need to get to install them?
Boost Demon said:Make sure you have an S-AFC or DSM Link or something to control them and that they have good upper o-rings and lower insulators on the bottom.
barf: ) and it's still a tad rich.They are exactly the same size as the stock injectors from the base of the pintle to the end of the inlet. The pintles may be longer, shorter, or the same as what you stock injectors were depending on what you had but that doesn't matter since they hang down in the insulator.eclipsegsx1736 said:he only issue I had was that the injectors are physically shorter than the stock ones, and if you install them like stock they won't be all the way in.
