Evo X license plate bracket write up> 2G
Just installed my Evo X license plate bracket. List of tools needed
-Drill + bits, max size needed is 1/2 inch
-dremel for grinding
-80 grit sandpaper
-screwdriver
all hardware comes with the bracket assembly
bracket i found cheapest was found here :MitsubishiParts.net - Your #1 Source for OEM Parts and Accessories
second from bottom, $31.60.....$42.55 shipped.
i was pleased with the outcome
start by drilling some holes. 1/2 inch to be exact
want to be able to push these bad boys in the holes you created.
in order to fit flush, you going to have to dremel and or sand down this edge
after that you want to line up your rubber anchor nuts with the bracket
tighten your screws down
and enjoy =]
Looks good man. Great write-up, better than getting pulled over for not having front plates or just tossing them up on the dash.
Making this a tech article so other members can easily find it.
