evo III turbo HELP!!!
Mitsu725
211
Mar 22, 2004
DAVIE, Florida
I bouught an evo III turbo with the exhaust part i think not the turbo part well it was ported and polished but where the headers bolt up to it there was a bolt broke in it, now i could get to the bolt from both sides and we tried drilling it out but the bolt was hardened steel so that didnt happend well to make a long story short we tried hitting it with a torch but u know wtf happened the cast melted a lil bit so im screwed now does ne one know where i can get a exhaust or whatever the other side of the evo III turbo is, and for how much or if someone can just tell me wher i can get one in south florida, PM me asap if u know ne thing thanx.
umm no the part i was referring to is called the turbine housing so i found out just now.
ah the infamous turbine housing bolt... i'm assume you're talking about the turbo to manifold bolt [ 1 of 4 ] i've broken one in also and it's just a matter of drill and tap.. check vfaq.com for a good walkthrough
but since you decided to melt your turbine housing just go on eBay.. i see them on sale sometimes
* edit * oh yea, i'm sure you can find a used 14b on here and use that as well.. since they're all mitsu tdo5h housings.. just remember to port it cause STOCK SUCKS!
