Evo III manifold
Jeff822
636
Jan 22, 2006
Easton, Pennsylvania
i was just curious i was planing on buying and evo 3 manifold b/c my stock manifold is cracked.......will the evo 3 manifold bolt right up to the stock turbo manifold and will it be alright for the stock o2 housing????
Yep it will work. Its casted a little larger on the inside and has a thicker manifold to head flange for the larger turbos to clear the water pipe. The o2 housing dont bolt to the exhaust manifold, so thats no problem. Everything will bolt up just like your factory one, even the heat shield.
well i have no heat sheilds on my car but umm the stock turbo gasket will work too.... i also think i have evo 16g turbo but thats wut the seller told me but thanks
yes, this will fit onto your DSM, and yes the turbo gasket for the 16G will fit perfectly as well, it is a 7cm gasket just like the stock turbo. Hope that helps you.
That is a real good mani.^^^, pretty cheap, flows great...not as well as tubulars but you dont want one of those if your putting it on a DD.But whats nice is you can have them port it for you before they send it to you, pretty good deal for the price.
brute said:
If you are buying an Evo III manifold, you might want to look into the SBR cast manifold since you are already upgrading... it flows more than a ported 2g or evo manifold and doesn't cost too much more. It's also cheaper than a tubular :thumb:
http://www.slowboyracing.com/more.php?id=1891&
Doesn't cost that much more?! WTF
It's around $100 more or 150% the price of an EVO III manifold.
Yeah true, but the runners are larger on the inside, the collector is bigger, and and the SBR out flows the evo3 as well, it also comes with the option of having it ported for you, for pretty cheap50$, and it comes pre"dimpled" without holes drilled yet, so if he gets a 38mm WG later it will be easy to install it, or if he has an internal WG with his turbo, he can keep it how it is. I think with all that the extra 127$ is worth it and when you compare it to the 500$+ tubulars it isnt really too much more.But its all up to him.
