EVO III creep control
jibberishballr
475
3
Aug 23, 2005
Chico, California
So im going to get an E316g, install kit, and the wastegate in the link below.
Do you think this will be adequate for no boost and will i need anything else for curing creep? I know i can port but with an external wastegate i dont need to right? Also i will be getting fuel mods, tuning, and fmic soon. Im just going to run the turbo at lower boost until then.
http://www.extremepsi.com/store/customer/product.php?productid=16320&cat=446
GRNDSM said:
Well, that just makes it even more worthless of a mod :). You can't port EVO 3 16G housing much past 30-31mm, so why bother with even larger valve?
When you find out, please inform me. I trust in what Josh (ShapeGSX) has repeatedly stated about that issue, and he makes seemingly valid arguments to support his statements.
The only reason I have come across that supports the purchase of an upgraded flapper is seen in Nathan's post.
I do not understand what you are trying to say. I asked a rhetorical question... So I am not waiting for an answer.
That's fine, Leon. I understand.
I was simply highlighting one "reason" why someone would support the purchase of a larger flapper valve.
