evo III
gsxboostin
229
Aug 13, 2004
Waterloo/Cedar Falls, Iowa
what psi can i run safely with stock fuel and an evo III? i hear 14-15, but someone also said 16 i didnt want to beleive that so i was just wondering, and could i put in my 550's and be ok, with out my s-afc installed yet? jus a thought.
hakcenter said:
Running a Stock.. fuel system, 5spd so its 450s
evo3 ported + evo3 mani + evo3 o2.. RRE 2.5 to 3inch DP to stock exaust.
I run 13-13.5 with 0 knock, at 14, I get from 10-20 counts...
So 13 is the safest without a logger.
You cant just go by your car for others to follow. Every car will perform differently. As for gsxboostin, the stock fuel system will only handle 14lbs on a 14b before hitting fuelcut, so i would say 11 max with the evo. I wouldnt put those 550's in until you get the afc installed. You need a way to control them :talon:
ok thanks a lot, i was wonderin i could find directions, and all i will need to install the s-afc jus cuz i dont know what wires to tap into for it. thanks -matt
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
