Evo III
Evo2G
Jul 16, 2010
seaford, Delaware
I have an Evo III in my 2g. I have a couple of issues ....
1. first when you go to start it in the mornings it doesn't like to stay running until it gets warmed up .
2. Car has a rough idle , some people say its a vac leak? ( whats the best way to find a vac leak?) I have changed the idle control mod, I have changed the intake manifold gasket, and all the vac lines Iam not using are capped off.
3. At a stop light if I get on it and go to shift gears , the engine continues to rev after I let off the gas with the clutch pressed in .... (only getting about 10 psi)
So Iam asking for advise . I bought this car in pieces I have got this car this far with help from you guys thanks .
Evo 3 what?
Turbo, o2 housing, intake manifold, exhaust manifold...?
Boost leak test should find any major vac/boost leaks.
Is the CEL on?
What exactly do you mean by "rough idle"? Are you referring to a bumpy idle, such as "missing"...or is it more like a surge? As far as idle mod do you mean the ISC? A throttle position sensor that is no longer functioning properly or not adjusted correctly can cause a bad idle. What are your RPMs looking like after a cold start compared to how it idles after it reaches operating temp? I know you said it doesn't like to stay running until it warms up but after a cold start is should still be in an RPM range that you can look at and give a description of. IOW, does it not want to idle high at all, or is it idling high and then stalling?
Evo III Block, head , and turbo.
whern engine is warm it idles at about 900 rpms . when cold it falled below 900 and stalls out .
Rough idle meaning a surge.
As for the tps had it tested witha voltage meter tested fine.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
