evo 9 pistons with .020over?
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
if you use evo 9 pistons and go .020 over on the bore, will they fit right?
basically are evo pistons bigger then stock 2g pistons, because I don't wanna go .020 over then get the same size pistons and have things not fit right.
OEM Evo pistons have the same 85mm bore size as we do.
So if you bored your motor over .020, you'd have to buy Evo pistons that are also .020 over (85.5mm)
They sure do, but if your allready bored .20 over you have a bunch of piston choices over the evo ones.
