evo/3g mas on 2g?
from everything I've read before today e85 requires ~30% more fuel
I think someone, somewhere got confused on the direction of the math and somehow that has stuck. Gasoline requires 33% less fuel than E85. But that means E85 requires nearly 50% more fuel than gasoline.
Bottom line, E85 requires 50% more fuel than gasoline to maintain its stoichiometric ratio.
Worse case scenerario how would it react to a 1g auto fpr with the higher base pressure?
That would actually work out perfectly! Good idea.
750 * sqrt(43.5 / 37) = 813
So you'd end up with an effective injector size of 813 cc/min.
In theory, the injector size you would need on E85 to behave like 550s on gasoline would be:
550 / 0.67 = 821
So you're there! Go for it.
Thomas Dorris
I have found my biggest problem to be discrepencies between published, and actual flow rates of injectors, and the variance in e-85 mixtures. I burn eproms, so the first thing i do is to run the car on stock injectors, and fuel pressure, to dial in whatever maf i am using. Even with a perfectly dialed in air meter at stock boost levels, i've had to go back to recalibrate the meter at higher flow, because of the different curves inherent to the different meters.
Local here ran 720s on 99 car with evo 8 maf. Car ran really well. made 335hp on the dyno at 20psi with a gt30r turbo setup. Engine was stock with fp1 cams. big e-bay intercooler 3 inch exhaust. wideband at 14.7 at idle and cruise. 13.7 at tip in/part throttle. 12.5 at part throttle excell. a little rich at WOT at 10/1. I was amazed it ran so well for no ecu tweaking..
OK. One question here. When using the 3g MAS is it off a 2.4 or 3.0 engine from the Eclipse?
The only Eclipse it was used on was the 2003-2005 GTS with the V-6 Variable Induction motor. All the other applications are the bigger motored Monteros, like 3.5 liter+.
