evo 3 exhaust manifold questions, please help!
Denji
Supporting Member
1,123
18
May 4, 2004
Calabash, North Carolina
Okay, i have an evo 3 exhaust manifold at my house with a t-28 killer on the way. I bought a die grinder with all intentions of removing the step on the evo 3 manifold, but.... i have these questions..
1. Without the metal ring gasket that goes in the exhaust manifold, will the manifold seal to the turbo properly and will it stay sealed? or should i not port it and buy a 7cm metal gasket ring?
2. Do i need to buy a 7cm gasket? or do i just widen the stock one? If i am correct mine is a 6cm.
thanks guys!
Good god. People still have that little ring that sits in with the manifold and turbine? Ditch it. Port match your manifold and buy a 7 cm gasket for it.
-T
Is there a 7cm gasket i can buy from a local parts store or do i gotta order that from slowboy or something? im impatient and i want to put this on soon.
I am porting the step tomorrow since you were disgusted with the idea of the ring gasket... Now i want to be disgusted too!.. damn gasket! :barf:
Drive up to machv then they shouldnt be that far theyre in virginia somewhere
i got mine from sbr... 7cm. i love being able to drive to sbr same day and grab any parts i need for an install.... ok im done rubbing it in.
Try ebay, some times SBR runs some sales on ebay especially on gaskets.
That's cute. You MD guys must just be jealous cause I can blow through your state in less than 2 hours.
-T
