evo 10 turbo TD05H-152G6
agentorange313
Supporting VIP
2,028
123
Dec 21, 2008
Westfield, New Jersey
I first want to say, this question might be the place for getting the answer but it also might be the website.
I have two questions about the evo 10 turbo(TD05H-152G6). since the turbo is a Mitsubishi manufactured turbo, and is a td05 housing, are the coolant/oil lines the same thread size as the previous Mitsubishi turbos like the 16g? The sizes are listed below.
MitsuTurbo 14b, 16g, 20g
Oil lines:
Head 6 bolt 4g63- 10mm x 1.25
Turbo - 12mm x 1.25
Coolant lines:
Turbo - 14mm x 1.5
Coolant Rail 6 bolt 4g63- 16mm x 1.5
My second question should be answered on a evo website, but I will throw it out there if anyone knows. I know the turbo housing inletfor the evo 10 is a mirror image of the evo 8+9, what I want to know is if the evo 10 o2 housing a mirror image of the evo 8+9 02 housing.
My goal is to make a custom exhaust downpipe for the evo 10 turbo on a 6 bolt 4g63. I have the exhaust manifold set up already, but I want to run an external wastegate. I need to fabricate a o2 housing using an evo 10 flange and make my own o2 housing. I haven't been able to find a evo 10 turbo outlet flange.
Thanks for the help.
the coolant line fittings are the same.
the 02 housing is not mirror image of 8/9. the x turbo is mounted on back of engine so down angle is different than front mounted. the flanges are not the same either.
