Everything fixed, does this look good!
hottboost
273
May 17, 2006
Romney, West Virginia
Wow, had alot of work to do. Boost leak at the bov flange, and tb. Always had mbc running off the bov T. Well when the boost leak occured I found out why that is a no no. Re routed it back to compressor housing. All good there. Now I think I got it re tuned. Pulled a few logs last night, boost would spike to 24psi then settle to 20 - 21 till red line. timing curve was smooth till redline, dipped to 7* then climbed steady line to 18*! I dont like the 24 psi spike but If its showing good on the logger should it be safe? All mods are current in profile.
Carl
As long as you have little to no knock and your injectors aren't running out, then you're probably ok. Check your EGT's and your A/F ratio at the spike if you have the means.
