Evap solenoid and fuel pressure solenoid. which is which?
moparmadd
40
Feb 27, 2005
Mason, Ohio
K so I am almost done installing the rebuilt motor and I am just about to start hooking up vacuum lines. I have a diagram of which to eliminate and where to plug but I was wondering which solenoid on the upper right of the enigine bay is which? The fuel pressure solenoid and whcih is the evap purge. Thanks everyone
Assuming you have federal, you should only have two side by side. The one closer to the passinger side is the purge control solenoid. The one on the driverside is the fuel pressure solenoid.
