ETS street IC and A/C lines
leepen
577
10
Dec 17, 2006
Las Vegas, Nevada
Anyone using both? :confused: The lines are right in the way. Some guidence if you are. Thanks
BTW bought the IC used and google didnt come up with any good instructions
EDIT short route
Those instructions didnt do shit, the pics were all blurry and they kind of made sense.
I had ac lines still in my car when i put my ETS short route piping in. After I enlarged the holes in the rad support, I bent the lines out of the way just enough to squeeze the pipes through, then bent them back so they wouldnt rub on anything (not alot of room to work with). But I have since removed my ac system due to it not working.
Moral of the story, you dont need to remove the ac lines if you dont want to.
Ended up having this made for the DS
Thanks..its been fun and cursing, sometimes at the same time. Now I need to figure out how to shoehorn the fans and scroud in there ROFL
Yes sir, I just pulled the a/c complete out because I couldn't fit the fan back in. I actually had problem with my pipe being long enough to fit all the way thorough the D shape hole
They cut and rewelded the hard line so it was about a 80deg, then put in the flex line, to the stock top swivel head. Not sure the exact details. they said what do you want, I told them they did it
