luizdiefenbach
- 32
- 2
- Jan 6, 2003
Brazil,
South America
Well, my car is a 1G Gsx, I bought a MAFT and I'm thinking in running this setup, please remeber that i will be running Ethanol and NOT Methanol....
1680cc/min (@43.5psi) bosch injectors with 30psi base pressure (so they flow 1400cc/min)to run with ethanol...
Ethanol needs 68% more volume than gas so 1400cc on ethanol is like 830cc on gas.... (830cc/min + 68% = 1400cc/min)
You think this could work ( at least until I get the 1G dsmlink) ? I think I will set the the MAFT BASE like this: AUX=2 (dsm eclipse 1G) BASE=A (830cc/min) , what do you think??
I know is this was on gas I will get a lot of timing but since im running ethanol I think its all good... (~100 octane rating) Do you think I will have too much timing or it will be good for ethanol?
should I turn up my base timing (via CAS) for ethanol too?
the fuel pressure wont be too low on idle for a good spray pattern???
any input is apreciated, I really don't want to buy the injectors and find out that I can't run them....
thanks and sorry for my bad english...
PS. I live in brazil and we have pure ethanol on pumps here.... (and much cheaper than gas) thats why the ethanol crazy stuff....
