maft
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
Can someone explain to me exactly how this will adjust your a/f? Is there a dial on it to adjust it? How easy is it to do? Does it work like an safc where it skews airflow readings to make your car add more fuel? I've never seen a maft in person so I'm just curious how easy this is to use and how to adjust it so I don't install it and run really rich or really lean. My injectors are 780s ... so is there a knob on there where you just turn it to your injector size or how is it adjusted? Any info on this would be appreciated.
Go to the full throttle speed tech forums and all of the instructions, descriptions, tuning guides, trouble shooting, and even the people who make them are all a click away. Yes it's a piggy back controller like the apexi that screws with the air signal and yes there are two knobs you use to control injector sizing/compensation and 3 others for different air flow range adjustments for tuning, then another "mode" for finer tuning in the WOT range.
  • Wanted 6 bolt NT water pipe
    • chrisman287
